×Hello, I'm using a bit of automation in my asset plugin, in order to create a Jira issue.
i have two attributes of my objects that I want to put as fields in the issue created, is this possible?
When you create custom field sourcing from Assets object, you can display the object attributes once the object is selected. However, you will not be able to create custom fields sourced from Assets against specific object attributes based on my experience and knowledge.
The underlying idea is the attribute is just additional metadata associated with the Asset object and not the object itself.
Sorry, Hope this helps.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Technology Applications Team
Viasat Inc.
Hello @Maria Elena Lovato ,
You can use Object created/updated/deleted trigger to create in issue.
Can you please provide more details on your use case, so that depending on that depending on that the solution can be proposed.
Vijay
The trigger isn't the issue fro me; everyday the automation run and check if a specific date is past today or not and then create a Jira issue. So far so good.
When the issue is created tho, I'd like to have the values of two of the objects attributes became the values of two fields of the issue.
