×Im hoping to get some help. We have a custom field (customfield_12971) that is used at two different ticket hierarchies. Initiative and Feature Level. We leverage this field for statuses (in a string format). What I want to do is roll all the child inputs of customfield_12971 into a singular output in the parent customfield_12971.
So essentially if there were 3 child tickets with statuses like the below:
Child 1 (customfield_12971) is:
Child 2 (customfield_12971) is:
Child 3 (customfield_12971) is:
Then the parent (customfield_12971) would be:
Note: this would be an automated push (happening weekly) so Im not too worried about syncing it up as a singular child ticket is updated (although that would be ideal)
I have a rule set up and it says it is successful but the info isnt populating in the parent at all. I suspect its because there are multiple children, any workarounds? Thanks in advance!
Hi @Travis Hill
First thing, what version of Jira are you using: Cloud, Server, or Data Center? That impacts how to solve this for the different versions of automation features.
For example, with Jira Cloud, the Lookup Issues action could be used to access the custom field and gather the results: https://support.atlassian.com/cloud-automation/docs/jira-automation-actions/#Lookup-issues
{{#lookupIssues}}
* {{customfield_12971}}
This would not work for Data Center version as Lookup Issues does not support custom fields yet. Instead a call to the REST API would likely be needed: https://community.atlassian.com/t5/Jira-articles/How-Can-I-Sum-Up-Multiple-Issues-into-a-Parent-Number-Field/bc-p/2883071#M16701
@Bill Sheboy that is helpful but I think the problem would be that I need to do this for several hundred tickets at a time and they dont have specific JQL other than them just being the same ticket type basically.
Also, with lookup issues isnt it only 100 at a time? We would exceed that I believe.
Backing up a bit: what problem are you trying to solve by doing this? That is, "why do this?" Knowing that may help reveal other solution approaches.
Until we know that...I will try to answer each part of your post, so please let me know if I miss something...
When a rule needs to update many issues, it helps to use a Scheduled Trigger with a JQL statement which can exclude issues that have already been processed (i.e., the "stopping criteria"), such as checking if a field is empty or a custom field to indicate the "last updated date / time by my rule". This would be the "stopping criteria". Without that, the rule will repeatedly process the same issues.
The JQL for the trigger could be quite simple, perhaps just the issue type, although it still needs some form of "stopping criteria", as described above.
That is correct. The Lookup Issues action can process a maximum of 100 issues, as the action relies on the REST API endpoint which has that limit.
The Scheduled Trigger has a higher limit, but the combined impact of the trigger and rule actions such as Lookup Issues could exceed other limits. Please look here to learn more: https://support.atlassian.com/cloud-automation/docs/automation-service-limits/
Yeah thats definitely a great question. The goal is essentially to do the following:
Thanks for that information, @Travis Hill
As this is a reporting need, have you considered investigating Atlassian marketplace apps / dashboard gadgets which could present a saved filter as a grid with selectable columns? That may allow showing parents with child issues below each for that reporting field, and allow drill-down when needed to the children.
This would dramatically reduce the amount of updates to the issues and the consumption of automation monthly usage allocation. And, reduce the risks of reporting errors if the rules fail / fail to run when expected.
@Bill Sheboy Thanks for reaching out! Unfortunately most of the gadgets available dont serve the need were looking to satisfy here and I dont think add ons from the marketplace are a viable option for us at this time (although I would agree that there are several which would make this exponentially easier on us lol). :(
Hi @Travis Hill, If I understand correctly you're using the Structure by Tempo add-on on Cloud. If so, you might want to click on the column heading of the Progress column and select Edit. They have some built-in options for rolling up progress that you may be able to make use of. HTH,
Kel
@Kelly Arrey thanks for the info, that could be helpful. However, its not quite about rolling up % here (although that plays into it a little), its about rolling up several strings into a field that are providing details on status.
So not, this Feature is 9% done but actually "this team is currently working on this aspect of the feature and is anticipating starting this aspect of the feature next" kind of thing.
@Bill Sheboy Ive been messing with your recommendations and I think Im sort of close to getting whats need using the lookup issues functionality. Now im just getting this error
Its obviously stemming from something Im doing in the rule that I cant quite put my finger on. Any thoughts?
Hi, @Travis Hill
The JSON you show is missing a closing curly-bracket: they need to be paired up to match.
And, that is assuming that structure works for the field type. When the field is text, the JSON would be this:
"fields": {
"customfield_12971": "{{customval}}"
When the field is another type, please look here to learn the correct syntax: https://support.atlassian.com/cloud-automation/docs/advanced-field-editing-using-json/
Thanks @Bill Sheboy that is helpful. The field is set up to be multi line text but Im still getting the error.
Please show images of your current Edit Issue Fields action and of the audit log showing thee rule execution.
Sorry, as I had a typo missing the closing quotation mark around the "fields" element. Please add that and re-test.
FYI...stuff like this is a good reason to first create the JSON in an editor which highlights matching syntax (i.e., quotes, brackets, etc.) and once it is correct, add it to the rule editor.
@Bill Sheboy it looks like it ran "successfully" so were getting closer. But the results didnt get added to the field.
Based on that log entry, there is something wrong with either your created variable or the edit.
The audit log entry showing what you tried for the JSON is incorrectly, so update it to exactly match what you are using in the edit issue action.
Next, please post an image of the create of customval and the edit.
Smart values are name, spacing, and case-sensitive. When an unknown smart value is used, that returns as null.
Thus it appears your variable name does not match what is used in the edit's JSON. Please change them to match and re-test. Thanks!
@Bill Sheboy hmmm, updated those to match (case, spacing etc) and its still throwing the same error. Unless youre saying the Smart Value in the Variable needs to be changed to match the JSON text. I didnt do that.
Whatever the name of the variable is, the declaration and uses need to match. Let's try for some alignment checks:
my variable is: {{whatever the name is now}}
Seeing these together will confirm which steps are (or are not) executing.
@Bill Sheboy thanks for your help on this I really appreciate it so far. Unfortunately my work wont allow for me to put any add ons or anything on (or extensions) so I did screenshots but lined them up way better this time.
Thanks for that information! The log is showing the variable is empty.
As the field is one of the text types, please change your created variable action to:
{{lookupIssues.customfield_12971}}
This will produce a comma-separated values list of the issue data.
If you wanted those to have the line breaks and bullets, change that to this:
{{#lookupIssues}}
@Bill Sheboy You absolute genius, that worked!!
I just have a small formatting issue
As you can see, it pulled everything in but the spots with the * should be on a new line since those were the Status Notes from different tickets. Is there an easy way to set that up?
Heres how I set up my variable action
Progress!
Let's try concatenating a newline after each value by updating that variable:
{{#lookupIssues}}
* {{customfield_12971.concat("\n")}}
Awesome! One more recommendation...
I recommend pausing, reading through this thread and your rule, and explaining it to another person. That will help solidify what helped in asking the question, the solution used, and tools to diagnose symptoms when rule-writing...and to share the knowledge with other teammates :^)
Have a great rest of your week!
