Hey there,
Per the subject, speaking with a small team of people who want to use Jira (40 people) and they want to start track assets and such but they have nothing in place now.
Would it be a good idea to have a form where they can add / update details for assets into 'Assets'. Just thinking that it may be an easier mechanism as opposed to going into Assets directly to find and edit objects.
What's the feel from the community for introducing asset management into a business when they have actually nothing in place now and how to create / edit their objects.
Hi @Ste404
you could consider using a Jira asset management app like STAGIL Assets that uses native Jira issues, fields and workflows for asset management and therefore ships with higher flexibility. It is also based on the native Jira forms.
Consider requesting a demo via support@stagil.com.
Best regards
Björn
@Ste404 -
Hi Steven:
For your team members, are they all agents for your JSM env? If so, then they can just access Assets option from the project UI menu dropdown to manage their Assets schema.
Or, you can also utilize automation rule setup to invoke Assets custom actions to manage objects based on your triggering event/conditions setup -
Hope this gives you some ideas.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Infrastructure Applications Team
Viasat Inc.
HI @Ste404 ,
A form would be a good idea. For example, you can use a request form along with automation to update assets when checkin and out an asset. or a request for replacement to update the current asset as broken/needs inspection.
-Ben
yeh I have a whole idea about a form driven approach but there is still no word on the Assets fields being available on forms, being able to leverage conditional visibility with a whole 'asset management' form would be great.
