Click to sort queue does not work for Custom Field of type "Text Field"?
CJ Edwards
I have added two example Custom Fields
SomeNumber_asText  as a Text Field (single line)
SomeNumber_asNumber  as a Number Field
Both have their respective default Search Template
Both are added to the screens as desired
Both are listed in a basic Queue in the TEAM PRIORITY Queue
Both show up in the Queue with their raw data as input (1234)
I can click and order SomeNumber_asNumber as it is a Number field
I can not click and order SomeNumber_asText.
Even if I insist in the JQL for the Filter for the Queue, it acts like it will order it, and does not.
The client does not want to use a Number field, as they do not want the commas or positive negative  or decimal values.
I am not crazy right? There is just no way to order text fields in a Queue?
Extra screenshot showing this works (as expected) in Normal Searches/Advanced
4 votes
Ste Wright
Hi @CJ Edwards
At this stage, this isn't available in the Queue view unfortunately
You can view/vote for this Feature here: JSDCLOUD-8170
Ste
CJ Edwards
Ahhh ok, so I am not crazy ;)
Better to know than to not know! thanks
