Hi there,
in the Jira issue history you will be able to see that an jira automation e.g. updated a field, set components or whatever.
However it only states "Jira automation updated xxx" - in order to speedup debugging it would be nice to have kind of "Jira automation (<name of jira automation>) updated xxx"
yes I am aware of the J4A-audit log and the global audit log ;)
Is there maybe an option I am not aware of or already an existing feature request to vote for ?
Hi @felix.weber
You can try Issue History app, it allows you to filter history log by changes made by Automation. This add-on was created by my team, so we will search how can we get data about automation names. When I will know the result, I let you know.
Hope it will help you
Regards
Add a comment in your automation with the automation naming / url. Then, set it to be visible only to your system admin group
Hi @felix.weber
There isn't such an option and even if you try getting the history with the API, there isn't such info. I've search about suggestions, but didn't see anything of interest. You could create on though!
