Adding a Comment using Smart Values
Bellina Bui December 15, 2022
Overview
Hello Atlassian Community!
For the past few hours I've been trying to figure out a way to copy a trigger comment over to a newly created issue type using Jira Automation.
I've had luck testing the audit log value of {{triggerIssue.comment.body}}.
However, in terms of copying over the actual comment from the original issue to the NEWLY created issue no luck.
Automation Rule
Trigger: Manual Trigger
Condition: Project = X
Action: Create a Task in Same Project
Problem
"update": {
"Comment": [
"add": "{{triggerIssue.comment.body}}"
The code block above is is not working.
I'd like the newly created issue to contain the old comments from the trigger issue.
Any help is appreciated thank you so much!
Gokaraju gopi
December 15, 2022
@Bellina Bui
Your requirement is not clear. A screenshot of your automation rule can help to improve it
Bellina Bui December 16, 2022
@Gokaraju gopi here you go :)
JITU GAMER
March 11, 2025
HELLO
