Automation: Create new issue with project given as user input
Thorsten Kamann
I am trying to build an action to create an issue in another project. The challenge is here that the user can choose in which project the issue should create.
For this, I created an action with a manual trigger. There is a prompt with a drop-down with the name of enabled projects.
My rule looks like:
But if I am executing the action, I got this error:
I tried it with the project key instead of the project name, too, with a similar result.
Has anyone an advice how to achieve this?
Thorsten
Tessa Tuteleers
Hey @Thorsten Kamann ,
You need the project ID as smart value to create issues.
You could make a lookup table to match the user readable name to the correct project ID, and create the issue with that.
You can find the project ID by going to the setting of the specific project, last part of the URL is the project ID.
yourBaseURL/secure/project/EditProject!default.jspa?pid=10703
Hope this helps!
Thorsten Kamann
Ok, but I don't get the ID via the URL. In my instance, the URL only contains the project key but not a numeric ID:
https://nnn.atlassian.net/jira/servicedesk/projects/ITH/settings/details
Tessa Tuteleers
Hi @Thorsten Kamann ,
in that case, you can use the API.
It is described here. The 3rd value should be the ID
Let me know if that works for you!
Thorsten Kamann
Yes, this works fine. Thanks for the hint.
