How to use smart values for automation that take values from the Description.
Eran Roiter
Hey all, i have automation that triggered every time the description is updated.
Then it creates a variable and uses smart values to edit a custom field and add tagged users from the description to the custom field.
When i edit the description at first and tag a user its working, but when i edit the description again and add another user it won't add him.
any ideas what I'm missing?
Thanks !
Bill Sheboy
June 28, 2024
Hi @Eran Roiter
For a question like this, please post an image of your complete automation rule, images of any relevant actions / conditions / branches, an image of the audit log details showing the rule execution, and explain what is not working as expected.  Those will provide context for the community to offer ideas.  Thanks!
Until we see those...
From what you describe, I hypothesize there is an error in using the match() function to parse out the mentioned users.
The match() function can have problems if there are newlines or multiple matches not handled properly.  Perhaps try this expression to get the account id values from the mentions:
{{issue.description.replace("\n"," ").split(" ").match("\[~accountid:(.*)\]").distinct}}
That replaces the newlines and then splits on spaces first, reducing the scope the match needs to check.  Then it returns only the distinct values in case someone is mentioned multiple times.
Eran Roiter
Thanks for you answer!
I will try what you suggested.
Eran Roiter
It worked !!! thanks :)
Like Bill Sheboy likes this
