Jira automation problem (edit issue comp)
Barış Özer
Hi
I am automating as in the attachment, but it gives an error. Can you help? In the Service Desk project, I want a ticket to be created at the date/time I want and its status to be "on hold".
Duc Thang TRAN
August 27, 2024
Hello @Barış Özer
I can suggest you add a  Branch rule / related issues  (Most recently created issue) then action -> status to "on Hold"
You need to check the workflow for the "Service Request" type to see if the rule actor can transition from the "Created" status to "On Hold." If not, you need to either follow the workflow or add a new condition.
Hope this can help
Barış Özer
Hi @Duc Thang TRAN
There was no solution. Why am I getting an error? Is there any detail in the screenshot?
Duc Thang TRAN
August 27, 2024
@Barış Özer
The issue occurs because, in your trigger, if you don't specify a JQL or a target, the automation can't determine which ticket needs to be transitioned.
That’s why I suggest adding a branch rule between creating the ticket and the transition. This way, the automation will set the created ticket to the "On Hold" status
Normaly this will work if rule actor dispose the right permissionCapture d’écran 2024-08-27 135750.png
Like Barış Özer likes this
